TRICITY BENDEX
  • #33899
    Robbiebegg
    I Have a problem with dw DH200W where it goes through cycle and stopped on drying, I need a exploded diagram and wiring circuit if anyone can help. How do you clear faults on these machines? I have checked fault code message but nothing for this appliance.
    #240522
    Re: TRICITY BENDEX
    Robbiebegg wrote:I need a exploded diagram and wiring circuit if anyone can help.
    The wiring diagram really won’t help you much I don’t think, you really should get the TDS disk to see what I mean by that. For £30 it’s worth the expense as it covers ALL lux stuff including this beast! 😉
    Robbiebeg wrote:How do you clear faults on these machines?
    There are 3 variants of this machine so the PNC number would help? Usually you press and hold the ‘S2’ programme option button then all the lights will flash for 30 seconds and the buzzer will sound. The programme/error terminates at that point! (hopefully?)
    I’ve emailed you some guff though…..HTH?
