Tricity Bendix AW1000W 914780744/00
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Tricity Bendix AW1000W 914780744/00
  • #24271
    DAR01
    Problem with this machine was drum jammed due to wood screw, belt had come off.
    Removed screw, refitted belt.
    Can set up machine on any program but pump runs for about 3 secs then machine does nothing.
    All wiring OK.
    I’ve had the same problem before on a Zanussi,changing the control mudule solved the problem.
    When these machines have a fault does the control module go into some sort off fault out condition, if so can it be reset or recofigured.
    If not best price on a module please.
    Mike
    #201376
    cab
    Re: Tricity Bendix AW1000W 914780744/00
    Hi one of my collegues had this fault today, e54 was stored in the fault code file, when he disconnected the motor it conntinued to drain ok, suspected motor!
    cab
