Tricity Bendix AW1001W wont start
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Tricity Bendix AW1001W wont start
  • #87225
    Plonky
    Hi all. My TB AW1001W just doesnt want to start. I have searched the previous fault posts but cant see anything that I can use to fix this problem. If I get the diagnostic lights to flash by holding down the start button and the adjacent button with a programme selected I get the Start and End lights flashing together once then the End light alone flashes a further 4 times and repeated. Help!
    #434258
    Plonky
    Re: Tricity Bendix AW1001W wont start
    Hi all, update.
    As none has yet come up with a fix for this problem I pulled out the washer and had a general basic check over and spray of WD40 on connectors.
    When I try to run it now the End light flashes 11 times…….. 😕
    #434259
    Press and hold the start pause and the one to the left of that for about five seconds to clear it as that doesn’t seem to make sense as a fault code.
    Plonky
    Hi kwatt, thanks for the help.
    Yesterday before my fiddle with it it would do a diagnostic sequential flash of all the lights and the start and end light sequence I mentioned now ALL it will do is flash End 11 times. Even without pressing any buttons. Just turn the dial to select any program and you get 11 flashes. Any ideas short of a gallon of petrol?
    #434261
    Doesn’t make any sense as a fault code unless another one is flashing as well.
    Plonky
    I can confirm it is the only light flashing. Door open or closed is the same.
    S
    #434263
    No idea then, sorry.
    Petrol may be a plan. 😉
    Plonky
    Bu88er!
    Now where is the petrol!
