Tricity Bendix AW1050 Timer
  • #4977
    Jonah
    Timer advances constantly when W/M switched on, had this on a Zanussi when the Tacho came out of the Sole motor, this one has a Ceset motor and it’s ok, I think it’s a timer fault but any views would be of help.
    Dave_Conway
    Re: Tricity Bendix AW1050 Timer
    I would still suspect a faulty tacho generator, or maybe the magnet has come unscrewed from the armature. If all appears OK, then it probably is the timer as it is the timer/module control everything type by the looks of it.
    #106711
    renno
    Faulty drain pump can cause similar problems. Hope this helps. 🙂
    #106712
    nemo
    could open/short circuit ntc cause fault ?
    #106713
    Jonah
    Thanks for all the info lads, I checked them all out and it would appear it is the Timer, again due to cost of replacement timer V new machine the customer opted for a new machine,no surprise there then !!!
    Thanks again
    Had a customer on the phone just now about one of these “finishing the programme in 15 minutes”. Clothes still wet I think she said. Has anyone had any further experiences of this fault?
    Mike.
    #106715
    Tony_EMW
    Classic fault on this model – change timer and all is solved. We of course stock them. Tony EMW
