Tricity/Bendix AW1200W
  • #6674
    bassman
    Can anyone help?
    I went to this machine Saturday, Pump had gone open circuit the winding had burnt, Fitted new pump tried machine on spin machine worked fine I then put machine on to wash the machine starts with a short pump and wash action but does not fill instead flashes four times and beeps four times which is a customer fault code for machine not emptying, According to user manual you cancel this after rectifying fault by pressing Start/Pause button but machine still does the same ,I had to leave machine come back to base and look up service manual on TDS DVD but all I can find is how to cancel last fault condition I phone cust to ask to try and cancel which is simple to do turn selector to position 10 and press Start button plus any other button for five seconds but still has same problem, Does anyone have any sugestions bfore I return on Monday.
    Tahnks Bassman
    #118974
    Re: Tricity/Bendix AW1200W
    Why did the pump burn out I wonder? Was it that the sump is blocked, ‘cos if the sump hose is blocked it will affect the air bell to pressure switch? ..thus no fill and go into default 💡
    Got to be trouble in that department I would say 😉
    Best of luck!
    bassman
    Thanks for that suggestion Martin Ill, check that on Monday I did think it may be a pressure switch problem.
    Bassman
