tricity bendix aw1400 end light & beeps
Home Forums Public Support Forums Help And Support Washing Machine Help Forum tricity bendix aw1400 end light & beeps
  • #22586
    brianhart
    Can anyone help?
    My AW1400 recently stopped working and the end light flashes & beeps 4 times, indicating that there is a problem with the door lock. I bought a new interlock, thinking that was the problem, but the machine still has the same fault.
    Is there anyway to reset the machine or something??
    Cheers for any suggestions.
    #195542
    lfcjoey
    Re: tricity bendix aw1400 end light & beeps
    disconnect the power before even reading this……. it could simply be the door catch that goes into the interlock is not quite springing back enough, it this is the case the door needs to be split and you will find a metal rod has come out of door catch mechanism, failing that a possible pcb fault.
    good luck
    power off please it hurts!!!!
