Tricity Bendix AW1560W
  • #34206
    bubs
    Have a Tricity Bendix AW1560W (914792706/00) auto. Customer reporting 3 beeps / flashes of the end light half way through wash. His manual gives 2 bleeps as a drain fault so can i assume 3 = E3? pressure switch type error?
    Had a quick look today, all looks ok, no blocks, fills to correct levels. If he starts the prog at a rinse or spin there is no error., just from the wash progs.
    Any clues as to likely a p/switch or pcb fault?
    Graeme
    #241685
    aqualectric
    Re: Tricity Bendix AW1560W
    Pressure switch faulty; heater faulty or earth leak @ heater; wiring problem or PCB failure. If it’s only on the wash, I would suggest heater first as the PCB and pressure switch are used at all other times throughout the wash cycle and rinses. 😉
    Hope that helps,
    Steve.
