Tricity Bendix BD911 Oven
  • #14733
    mike412
    Got this job to go to on Friday. Fit part I ordered before Xmas.
    (Main Oven Door Seal 3116930011).
    I have never fitted one of these before and would like to be better informed before I go.
    Is this a soap and sqeeze down the gap around the oven cavity or am I likely to encounter something more challenging?.
    Thanks in anticipation,
    Mike.
    #160621
    eng14
    Re: Tricity Bendix BD911 Oven
    hi you remove screws from front cavity,take door away first ,then seal will go around surround hole and screw back,richard,same as zanussi 🙂
    #160622
    aqualectric
    Loosen the screws around the oven cavity, but beware, the screw in the middle at the bottom below the seal joint only holds a support bracket for the centre of the oven cavity. Undo it one turn or so until you can just gently prise the front panel away from cavity with a terminal screwdriver. I unscrewed one completely once -bracket fell off into vent space below oven- loads of fun getting it back in place. (take care not to chip enamel) Press end of seal into gap, pull out screwdriver from panel and continue to press seal around the oven until the ends meet. Retighten screws as you progress past them just enough to stop the seal popping off. When seal is central and even, tighten all screws. Job done. Drink coffee.
    #160623
    mike412
    Thanks Guys, Should save me loads of time on Friday, got a heavy day building up.
    Cheers,
    Mike.
