TRICITY BENDIX BD921 GRILL DOOR SEAL FITTING
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries TRICITY BENDIX BD921 GRILL DOOR SEAL FITTING
  • #58843
    bmrenr
    Hi I have to fit a door seal to the above appliance but its not like anyone iv fitted before .It has no hooks I think it just fits into a cavity.Does anyone have any advice on how to fit this.
    Tom.
    #335849
    aqualectric
    Re: TRICITY BENDIX BD921 GRILL DOOR SEAL FITTING
    With the oven door open, remove the screws holding the oven to the furniture cabinet. Then loosen the five screws around the oven frame just enough to remove the old seal. ( don’t remove them completely!)
    Starting at the bottom centre, push the seal into the gap between the oven cavity and the front frame. Follow round, making sure the seal is even and seated correctly. After fitting the whole seal, it may be necessary to cut off the excess with a sharp knife. Butt the ends together tightly; cut the seal a tad oversize to achieve this. Patience is the key!!
    Hope that helps,
    Steve.
    #335850
    bmrenr
    Cheers Steve .
    Tom.
