tricity bendix biw 102
  • #15216
    pclovejoy
    Hi i have purchased a pair of new bearings for the drum on my machine, on removing the back panel have removed the belt and now am faced with the problem of removing the torx bolt from the drum i cannot seem to shift it at the moment and now am wondering if the bolt has a opposite thread, can any one help please
    #162662
    Re: tricity bendix biw 102
    Er, the pulley bolt is the least of your problems….. It is a rh thread BTW. You do realise that the entire tank assembly must be removed and split to allow you to fit the bearings and seal, and that you will need a tub half gasket as well?
    Good luck,
