Tricity bendix BIW102
  • #80756
    Marcos101
    Hi all i have a tricity bendix biw 102 which is taking a couple of hours to do any washing cycle.It spins ok as in its not slow,i have put hot water from kettle in to powder draw to see if it was something to do with the heating of the water but still the same.I’ve checked if any water was comeing out of the outlet while on a cycle but it’s not.
    Any help would be great
    Regards Marcus
    #414038
    Re: Tricity bendix BIW102
    It could be a number of things:
    Slow fill, blocked/scaled up inlet filters?
    Faulty heating element?
    Blocked/scaled up drain hoses, drain filter, air pressure chamber?
    Plenty to start you off there. 😀
    #414039
    Marcos101
    Cheers Martin plenty to be going on with,will have a go and let you know how i get on.
    #414040
    Andy jones
    Try to narrow the cause down. Does it take ages to fill, drain etc
