Tricity Bendix BIW105W…pnc 914213009 01
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Tricity Bendix BIW105W…pnc 914213009 01
  • #67892
    robbra
    Select programme and pump runs for 3 seconds then nothing.
    No fault code flashing. Door locks.
    TDS disc shows no diagnosis programme so at a bit of a loss.
    motor, door lock,valves,pump and heater all check ok.
    Is there a diagnosis for a similar model I could use from the TDS?
    Any help welcome.
    Rob
    #368882
    geoff1
    Re: Tricity Bendix BIW105W…pnc 914213009 01
    Hi Rob
    have emailed some information to you on the module I suspect the machine has.
    Sent to email on your website.
    HTH
    Geoff
    #368883
    robbra
    Spot on Geoff,
    Wonder why it’s not on TDS under that machine. Saved it now so will be handy in the future.
    Many Thanks,
    Rob
    #368884
    Damp? Might not necessarily show up on megger.
    Mike.
    #368885
    robbra
    Yes Mike, I did tell her that it was in a damp corner and the motor had a film of damp on it.
    I’m going back later armed with a hairdryer.
    Forgot to mention it before. 😳
    Will report back.
