Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Tricity bendix CDW 087 – Program not moving.
- This topic has 9 replies, 2 voices, and was last updated 19 years, 3 months ago by
Jamz.
January 9, 2007 at 7:55 pm #23983
Jamz
ParticipantHi,
The program dial doesn’t seem to move on once i start it, I’ve cleaned all the parts in the bottom but it hasn’t helped.
Any ideas?
January 10, 2007 at 1:25 am #200078Penguin45
ParticipantRe: Tricity bendix CDW 087 – Program not moving.
This is always a good starting point for odd faults:
http://www.ukwhitegoods.co.uk/modules.p … ge&pid=104Failing that, broken wiring in the door or dead timer motor are worth investigating.
Power off, of course.
Penguin45.January 10, 2007 at 4:35 pm #200079Jamz
Yeah I’ve cleaned those blue pipes so now I’ll checkout the horse shoe.
How easy and expensive would it be if it’s wiring or the knob motor?
January 10, 2007 at 8:55 pm #200080Penguin45
Broken wiring is usually a patience job – check the area where the door pivots. If the timer motor has failed (unusual) you would be looking at replacing the timer as a unit – usually around the £80 mark.
Penguin45.January 12, 2007 at 7:52 am #200081Jamz
Right, I cleaned the horseshoe hose last night and the dishwasher did a full cycle, but it wont do a second one. Do i need to check all the hoses again?
January 12, 2007 at 7:50 pm #200082Penguin45
If it’s run a full cycle, you can eliminate the timer and wiring, so water level system it’s got to be….. Also check that the two airhoses have not got water in them – one goes to the level switch, the other to the inlet valve.
Stay safe – power off.
January 21, 2007 at 5:36 pm #200083Jamz
I’ve done all the pipes again and it’s ran a cycle and a new one is just running now, I did notice once the 1st cycle was done that there was still alot of water in the bottom… is this normal?
January 21, 2007 at 5:51 pm #200084Penguin45
There is always a bit of water left in the machine, but it should be below the level of the filters.
January 21, 2007 at 6:14 pm #200085Jamz
humm, again it did the 1st cycle but wont do a second…
should i bin it?
January 23, 2007 at 12:41 am #200086Penguin45
Shame really – don’t know what else to suggest. The inlet valve may be tripping on a nuisance basis – they do get old and the pnuematic system gets tired if repeatedly tripped.
Have you checked for a local independent engineer in your area?
Penguin45. -
