Tricity Bendix CWD100 Washer/Dryer Leak
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Tricity Bendix CWD100 Washer/Dryer Leak
  • #79948
    jontymox
    Good afternoon,
    Wondering if anyone can assist with a leak from the condensing tank overflow on the above m/c?
    I have not come across such a leak, and have checked for blockages in the system.
    I wonder what the purpose of the small red unit at the rear of the dispenser is, and where else I should be inspecting?
    jonty
    #411158
    Re: Tricity Bendix CWD100 Washer/Dryer Leak
    jontymox wrote:Wondering if anyone can assist with a leak from the condensing tank overflow on the above m/c?
    The tank overflow? Do you mean the air vent at the top of the condenser matrix?
    jontymox wrote:I wonder what the purpose of the small red unit at the rear of the dispenser is, and where else I should be inspecting?
    At the back is the water inlet air break for the dryer valve. They scale up and often need replacing especially as this machine is ancient anyway. Or do you mean the water distributor at the top of the dispenser? That is a mechanical linkage to the timer cam.
