Tricity Bendix DH086
  • #7108
    BobHope
    Anyone help with this one, this dishwasher keeps going into anti flood.
    Done all the normal checks cleaned the syphon tubes and all that, machine works fine when the water inlet pressure is released some times for days then the fault returns.
    Cheers Bob.
    #121448
    Faulty diaphragm on inlet valve most likely culprit – had this a few times and had to replace the valve.
    Simon46
    Re: Tricity Bendix DH086
    Make sure no water has gone down the tubes or is in the diaphraghm.
    #121450
    BobHope
    Cheers Chris,
    have allready ordered inlet valve and pressure switch, nice to have a second opinion.
    Thanks Bob.
    #121451
    The-specialist
    The air chamber is blocked m8.And overfilling .
    You will need to fit new sump 😆
