tricity bendix dh086 not emptying
Home Forums Public Support Forums Help And Support Dishwasher Help Forum tricity bendix dh086 not emptying
  • #22358
    summerset21
    my faithful dishwasher has decided to stop emptying any ideas on what could be wrong? i have checked the outlet pipe and this is not blocked
    do not know what else to try!any help appreciated
    thanks
    #194621
    Re: tricity bendix dh086 not emptying
    You can access the drain pump impellor from under the filters. It will almost certainly have eaten something which has disagreed with it. Bail as much water as you can by hand first, or you won’t be able to see what you’re doing.
    Trilobite
    POWER OFF FIRST!
    And take great care: broken glass can be invisible in water!
    #194623
    summerset21
    i have cleaned all the parts visible under the filters but still the machine wont empty!
    #194624
    The drain pump cover is at approx, the 1 o’clock position.
    summerset21
    Penguin45 wrote:The drain pump cover is at approx, the 1 o’clock position.
    i have checked this and completely cleaned every part took it all to pieces cleaned it and put it all back still not emptying i suck the water out via the outlet pipe with a vax machine so i know there are no blockages?
    #194626
    So is the pump actually running? Is the impellor free to turn?
    summerset21
    Penguin45 wrote:So is the pump actually running? Is the impellor free to turn?
    what does the impellor look like??? so when i undid all the screws i came across a thing that looks like a fan there is nothing at one oclock that moves ? sorry for being so thick
    #194628
    There is a big hump at about 11 o’clock – thats the impellor (propellor) for the circulation pump. To its right, behind and under the translucent tube running across is the cover for the drain pump.
    summerset21
    Penguin45 wrote:There is a big hump at about 11 o’clock – thats the impellor (propellor) for the circulation pump. To its right, behind and under the translucent tube running across is the cover for the drain pump.
    no blockages but how do i check if its working?
    #194630
    gegsy
    If there are no blockages and the impeller is still attached to metal shaft of drain pump, it should empty.
    Perhaps Trilobite has something useful to add besides power off 😀
    summerset21
    Whilst the internet is a wonderful tool, it does have its limitations. I think that we may have reached that in this instance. In all honesty it may be time to contact a local engineer to come and have a look at your machine.
    If you can find no obstructions to the pump, then checking the pump, the wiring, and control systems is the next step, something best left to someone with the correct technical information, test equipment and expertise.
    Click the link in my sig to see if we have someone who can help.
