hi ,got a call today about this d/w it heats up but then stops .is this something to do with the pressure system .i think this has the blue tubes as discussed on the fourm before .will cleaning them out solve this problem?
thanks
thanks for that .do you know how high the water level should be in this D/W?i cleaned the blue tubes but the machine stoped at a different stage in the wash process near to the end.should the pressure switch have two levels ?
thanks
