Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Tricity Bendix DH090
- This topic has 9 replies, 5 voices, and was last updated 12 years, 7 months ago by
fionamarie.
August 22, 2013 at 9:14 am #76802
fionamarie
ParticipantI have a tricity bendix dh090 dishwasher that has decided to go on strike! sometimes it will go all the way through from the beginning to the end with no problems, and sometimes stops mid cycle. My other half has cleaned the blue pipes and the parts below the large filter, and it did work for one wash, now its back to not working. Any idea? Thanks in advance.
August 22, 2013 at 10:38 am #399876kwatt
KeymasterRe: Tricity Bendix DH090
It could be pretty much anything but I’d check the heater and thermostats first.
August 22, 2013 at 12:02 pm #399877fionamarie
ParticipantRe: Tricity Bendix DH090
thanks for the reply, its just done a wash, got stuck just before 3, turned the dial till it started again, and it completed the wash. Hot water, heat to dry etc, arm sprayers moving.
August 22, 2013 at 12:11 pm #399878tuffy
Hi yep try cleaning both the syphon tubes check the small tube at the base of the chamber that holds the syphon tubes hope it helps
August 22, 2013 at 12:36 pm #399879fionamarie
Thanks, will get my other half to give it a go when he gets chance, and get back to you
August 25, 2013 at 12:55 pm #399880fionamarie
well, we took the pipes out as advised and cleaned them, the u shaped tube underneath was full of muck! after putting it all back together and putting it on a wash it filled with water, and began to wash, however it seems as though the heater is kicking in but the intake of water has stopped 🙁
August 25, 2013 at 2:19 pm #399881Simon46
Water or crud in airtubes going to inlet valve or pressure switch. Mechanical diaphragm on valve may have been forced to shut off electric inlet valve. Pressure needs releasing by pulling tube off and tapping valve. Unplug power if your going in.
S.August 25, 2013 at 2:27 pm #399882Andy jones
Sometimes taking off the hose at the supply will also release the pressure
Sent from my iPad using Tapatalk HDAugust 25, 2013 at 3:34 pm #399883fionamarie
Simon46 wrote:Water or crud in airtubes going to inlet valve or pressure switch. Mechanical diaphragm on valve may have been forced to shut off electric inlet valve. Pressure needs releasing by pulling tube off and tapping valve. Unplug power if your going in.
S.are there any diagrams so we know what we are looking for?
August 25, 2013 at 5:41 pm #399884Simon46
Sorry no.
