Re: tricity bendix dh101 not emptying ?
Bail it out first. Motor should run in two directions, one for circulation and the other for drain. If the motor is running, there may be a blockage past the motor, but more likely the impellor stack has stripped its blades. If it doesn’t run at all, it gets a bit complicated.
You can remove the motor for inspection from the back – remove the metal bar and the motor pulls out to the rear.
THIS is what you should be looking at.
Stay safe, power off first.
