Tricity Bendix DH102D.
  • #10717
    ChrisR
    Hi guys.
    According to the customer this dishwasher was working fine and then,all of a sudden,the next time she used it water started leaking from the right hand corner.
    I removed the door panal and put it on a programme and surely enough as soon as it started washing water leaked from the right hand corner.
    It appears to be as the spray arm rotates and the water jets across into the corner it splashes up into the bottom section and overflows down onto the floor.
    The problem is theres no obvious reason why.
    Door seals ok.water level ok,dishwasher standing level.
    Door hinges ok and no distortion of door itself.
    It seems to me that a gap between the bottom of the door and the floor of the dishwasher exists and the water is rushing through there but why leak all of a sudden?
    A plastic deflector would do the trick……is anybody aware of this fault and maybe a cure.
    ( Sorry to have gone on a bit).
    pup
    Re: Tricity Bendix DH102D.
    hi
    check, tub seal where it meets the door at the bottom, sometimes they
    expand and therfore stops the flow of water as it is spraying, also check
    bottom spray arm make sure it is right way up. If it is the seal all you
    need to do is cut little bit off at the bottom of the seal
    #141638
    Original door bottom seal is a supeceded number; which speaks volumes……… New p/no is 1527401-00/1.
    HTH,
    ChrisR
    Thanks.
    Both seals have been changed recently and seem OK.
