Hi all, This dishwasher stops at each program as it’s going round. Start at “1” and it will stop at “2”, start at “2” and it will stop at “3” and so on. whereas before it would go through to the end. It’s heating up, washing and draining fine. Any ideas?
Many thanks.
Ashby
Can’t find that model no. anywhere.
If it’s quite old, does it have the blue tubes in the pressure system when you unscrew the hat shaped thing on right of sump inside tub? Have you cleaned them out? That would cause prog. to stop whilst waiting for water. Or horsehoe tube underneath.
Mike.
