My dishwasher, which is less than 3 years old, has abruptly stopped working. it worked perfectly a few days ago!
When I switch it on, it makes usual noise for approx 10 seconds, but water does not begin to fill, then all noise stops.
I have cleaned filter, have checked that water is on. I have removed water pipe from plubing i.e. pipe feeding from plumbing which hose is attached to – to make sure there was no blockage here.
Have also removed u-bend from sink – just in case there was some blockage there, that might somehow be causing problem! :'(
The lights flash as per usual when I cancel the wash, so no error message showing up.
Would be grateful for any advice on this – & also opinion as to whether it is worth getting an expert to come & look at this, or if I should just replace it!?
Thank you
