Tricity Bendix fan oven element
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Tricity Bendix fan oven element
  • #95292
    Cazzah
    Hi. My fan oven element went last week so I got a spare element that said compatible with the Tricity Bendix TBF 650X. Went to fit new element but the brackets on the old one and new one are different sizes. The new one is smaller so when fitted I can’t actually screw the bracket on. It’s just sitting there with a wee space above it. Is this ok to use? I’m afraid that the wires that have attached onto the element at the back could be exposed due to the bracket being too small. Thanks for any advice
    #459932
    Where did you purchase the element from, has the packaging got any part number on it?
    THIS is the correct element for your appliance.
    #459933
    Cazzah
    I got it off homespares and the new element is the exact same as the one you have recommended. Part number 3970123018 is exactly the same one I have got and the bracket doesn’t fit.
    #459934
    Can you give us the full pnc or product number of your cooker?
    #459935
    RocketMan
    Definitely serial number dependent. “
    This element is serial number dependant. Please contact Customer Services on 01325 302464.” From Zanuusi UK website. (Zanussi look after TB spares).
    As other have said already, full PNC and pnc needed and then it can easily confirmed which element is required. UKWG shop can supply
    #459937
    Cazzah
    Thanks. The pnc is 949712315. Serial no 62914926
    #459938
    Here you go, yours is the earlier type.
