I have had my Tricity Bendix Fridge Freezer for a couple of years with no problems, I have just moved house and now the fridge section is freezing everything in the fridge, even on the lowest setting. It is model number TB 117 FF. The freezer is working fine, the fridge has a little bit of ice on the back, but not much. I have tried turning it off and then back on again, and I tried cleaning out the little drainage hole at the back….
Is this a thermostat problem? And if I buy a new thermostat, is it simple enough to change?
Thanks for all your help! 😀
