Re: Tricity bendix impellor change
Simon, the 2 red wires are for the tacho control which is only used on the electronic controlled machines so if youre going to fit it to a dh102 just leave it disconnected. As long as the impellor has the same number of blades on it as the old one there shouldn’t be a problem, if it has more then it will affect the water pressure which reduces the water level left in the sump and can lead to overfilling problems.
