Went to this today expecting to pop a brush set on its motor, but no. Mod is AW1000, if you select spin it does 3 or 4 short distribute spins but just as you expect it to go into main spin it clicks through to stop.
checked all usual suspects & can only assume its the prog, havnt seen this before on this normally reliable wee machine though, anyone got any other ideas? Thanks.
9 different versions of this machine will need production number and version, it could be module but from memory i have replaced timers on them for similar faults hope this helps
