Home › Forums › Public Support Forums › Help And Support › Cooker And Oven Forum › Tricity Bendix Oven Door Brackets Fell Off
- This topic has 11 replies, 3 voices, and was last updated 21 years, 5 months ago by
admin.
October 26, 2004 at 7:22 am #6628
KeymasterHi,
My oven door has two plastic brackets glued to the bottom of the outer glass door that hook on to a fitting on the inner door. After my wife cleaned the cooker they fell off, but I can’t find a suitable glue to stick them back on again. The black plastic brackets seem to have a whiteish way plastic material backing. Any ideas please?October 26, 2004 at 7:39 am #118720Martin
ParticipantRe: Tricity Bendix Oven Door Brackets Fell Off
Give us the model number of the oven then we can look up what you may need to fix it 😉
October 27, 2004 at 10:49 am #118721admin
KeymasterI have the Model and Product Numbers
Thanks for offering to help.The model number is: S1453W and the product number is 948518017.
I look forward to seeing your reply.
October 27, 2004 at 12:05 pm #118722Dave_Conway
The recommended repair would be to replace the outer door glass which comes complete with the brackets pre-glued, it is £64.33 inc VAT.
You can however buy the high temperature glue which can be used to re-glue various cooker manufacturers doors/glass panels etc for £10 a tube.
If you want either, drop me an email and I’ll sort for you.
October 29, 2004 at 7:16 am #118723admin
KeymasterRe: Tricity Bendix Oven Door Brackets Fell Off
Thanks for that Dave,
I’d like to try the glue. If you let me know how to get it, that would be great. I tried a 150 deg.C Araldite but it did not stick to the glass.John
October 29, 2004 at 9:07 am #118724Dave_Conway
Give us a ring on 01392 467889 (ask for Jess) she’ll sort it for you.
What do you present by the way ?
November 1, 2004 at 9:01 am #118725admin
Hi Dave,
Thanks, I spoke to Jess and the glue is on its way – I’ll report back when I try it out.
I present Electronics by the way (a bit boring I guess).John
November 1, 2004 at 12:31 pm #118726Dave_Conway
Ok thanks John.
Let it cure for 12 hours before refitting the door glass 😉
November 24, 2004 at 8:10 am #118727admin
KeymasterDave_Conway wrote:Ok thanks John.
I was interested to see this correspondence – the door brackets fell off my Tricity Bendix oven last night! It’s a different model (BS612/2B), but presumably it’s a matter of a new door or some glue as you said previously. Any idea how much a new door would be, and where I can get it? (It’s brown).
November 24, 2004 at 9:42 am #118728Dave_Conway
The outer door glass with the brackets attached is £65.61 inc VAT and postage or you can re-glue them as above, the same advice applies.
I can supply either for you.
December 2, 2004 at 4:24 pm #118729admin
Thanks for all the help – the glue arrived really quickly and worked a treat and the oven’s back in action.
December 2, 2004 at 5:09 pm #118730Dave_Conway
Good news then 😀
Thanks for letting us know.
