Home › Forums › Public Support Forums › Spare Parts Help › Tricity Bendix oven door (bs-692-ss)/AEG micromat plugs
- This topic has 6 replies, 3 voices, and was last updated 20 years, 2 months ago by
SockToy.
January 23, 2006 at 10:37 pm #15078
SockToy
ParticipantHi,
For no apparent reason whatsoever my oven, about 7 years old, decided to shatter the outer pane of glass in its double glazed door. I’ve removed the door and broken glass fairly easily, but the outer pane seems to have simply been hotglued on.
I’m assuming its some kind of heat resistant glue, and I dont have any, so I’m looking for a quote on a replacement door unit in its entirity, or , I suppose information/help on replacing just the front glass, and whether this is just one of those things or there’s something more fundamental wrong with the oven.
Model number is BS-692-SS, Branded ‘Tricity Bendix Professional’, fitted single electric oven.
I’m also looking for some of the little plastic fixing plugs that hold the fan guard and lightbulb panel on for an AEG Micromat 1000, Model ‘micromat 1251-E’. ServiceForce want an amazing 50 quid for them.
The Electrolux online parts finder appears to be broken at the moment so I cant check there…
Thanks for any help 😉
Matt
January 23, 2006 at 11:41 pm #161939Dave_Conway
ParticipantRe: Tricity Bendix oven door (bs-692-ss)/AEG micromat plugs
The outer glass will come with the brackets already glued in place, don’t chuck the handle or any other parts out as you can’t buy the whole door 😉
Can you post back the PNC or ENR for the microwave and I’ll check in the morning for you for both, I can idetify the oven glass but no price as the trade part of Electrolux’s spares is also down 🙁
January 24, 2006 at 12:42 am #161940SockToy
The microwave only has the following information on its tag:
AEG Micromat 1251-E
E-Nr.611.840 710
E EH 8743When I talk about the door glass being glued in I mean literally that – while the inner glass is suspended on little clippy brackets the outer glass was held in by a circle of bulbous glue running around all the edges, there are no clips visible.
Eek.
January 24, 2006 at 12:54 am #161941Penguin45
Push rivet for cover panels on microwave – 8996619177-26/5 – about 70p each. Plus VAT. Contact spares@ukwhitegoods.co.uk for confirmed prices and ordering.
http://www.ukwhitegoods.co.uk/modules.p … cts_id=302
This stuff will stick anything to everything for ever by the way…… 😀 .
Penguin45.January 24, 2006 at 9:34 am #161942Dave_Conway
As the glass has shattered, it is part number 357 82 64-17/2 at £68.42 ex VAT and carriage.
Same email address if you’d like ordering 🙂
January 24, 2006 at 10:50 am #161943SockToy
Excellent – the glue is described as ‘operational to 230degrees c’. The oven runs to, as I recall, 250. Is that going to be problematic? 😉
If not I’ll drop an email and order the parts ASAP. Thanks.
January 24, 2006 at 11:07 am #161944Dave_Conway
I don’t think you’ll need it to be honest, as mentioned, the glass will come with any brackets etc already in place.
But yes, it’s fine for oven doors etc.
