tricity bendix re60dcw timer bypass
Home Forums Public Support Forums Help And Support Cooker And Oven Forum tricity bendix re60dcw timer bypass
  • #60792
    st2boy
    i need advice on bypassing the failed timer on my tricity re60dcw cooker.
    i replaced the single regulator on one of the plates ,but unfortunately i trapped the orange feed wire from the timer to the main oven thermostat.
    the result caused a dead short in the timer clock. now the fan and oven light come on as soon as the main cooker switch at the wall is switched on.
    it must surely be possible to by pass the timer as i only use the oven on a manual setting.
    regards st2boy
    #343657
    Seamy
    Re: tricity bendix re60dcw timer bypass
    Perhaps you should consider getting an engineer to check it out.
    Its dangerous if you bypass the wrong thing, you say how the fan & light comes on as soon as switched on at wall, if element were to come on & heat when its not supposed to for instance because of faulty wiring there could be a dangerous situation.
