Hello,
Mum has removed the outer door from the grill to clean behind the glass and now cannot get it back on.
I have had a look and there are two tabs on the bottom of the outer door which line up with two holes in the bottom of the inner door, then two screws go through the trim piece and through the top of the inner door but the captive nuts they screw into are about 10mm away and if the outer door is lifted to meet the screws the tabs come out of the holes in the bottom.
Obviously I am either looking at it wrong or there is a part missing??
Any help gratefully accepted,
Thanks,
Tony.
