tricity bendix tbdw41 Dishwashwasher Help!!
Home Forums Public Support Forums Help And Support Dishwasher Help Forum tricity bendix tbdw41 Dishwashwasher Help!!
  • #31621
    nacnud
    I have the above dishwasher and it leaks from underneath i have had a look on this site but as i am new to the world of diy and fixing things! (just brought my 1st house) i need a bit of help!
    how did i find if its doing the below
    Regeneration chamber
    • Overfilling
    Sump seal
    Any help would be great!
    Cheers
    Duncan
    #231881
    Re: tricity bendix tbdw41 Dishwashwasher Help!!
    Most likely source of the leak on one of these is from the joint where the motor joins the underframe. Everything else is in the underframe itself.
    Power off, if investigating.
    nacnud
    So in basicaly i need to get in there and take everything out then and get into the belly of the machine!!
    Nacnud
    #231883
    Er, I think I might start by looking underneath with a torch first……..
    nacnud
    right i did that last night! also i found that water is coming out from the the front underneath the door.
    when i when under neath i noticed that the front was wet, so filled it up and noticed the water leaking out from what i can only decribe as a where the metal bit attahces to the plastic!!!
    any ideas?
    thanks for your answers Mr Penguin!
    Dunc
    #231885
    You need to have a check of the water level – if you stop it when it’s circulating, the water should fill the central depression where the filters are and not much more. If this seems correct, it is possible that the bottom door seal is failing – you’ll need to remove the decor door and door outer panel to see properly.
    Power off, first.
    nacnud
    Mr P
    Thanks for that i spent a few hours look at the door pannel last night and could not work out how to getthe decor off! i will have another look tonight but do you have any tips?
    Cheers
    Dunc
    #231887
    Decor panel is usually 2, sometimes 4 screws going right through the wood.
    Metal outer panel is the row of screws down the edge of the stainless inner panel and two on the side of the door.
    nacnud
    I could not see that but now i know i will have a loook for it!
    Thank you for your time with this you are a great help.
    Dunc
