Tricity Bendix TM310W condensor dryer
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Tricity Bendix TM310W condensor dryer
  • #54541
    Micky 32
    Went to this today, full tank light aparntly comes on and stops. It was lying up for 2 weeks when i got there so it ran ok. Bottom tank was dry so if it was full of water it dried up. Seems clean and float isn’t sticking.
    However , is it normal for the pump to work only intermittent on these like every few mins and then run for a couple of minutes and stop? Or should it run continuely while operating?
    #320021
    geoff1
    Re: Tricity Bendix TM310W condensor dryer
    There are two relays that control the direction of the motor.
    Relay 1 motor goes anti clockwise
    relay 2 motor now goes in clockwise direction and also activates the pump.
    Short is that pump only runs when the drum is turning in a clockwise direction
    HTH
    Geoff
