Following clearing a totally blocked filter on my daughter’s drier, the machine will now only start and run provided the ‘ON’ button is pushed and held in manually. The solenoid close to the timer does not latch.
Re: Tricity Bendix TM310W only works if I hold the start but
IS THIS A CONDENSER IF SO LOOK AT THE BACK DOWN THE BOTTOM THERE IS A SMALL RUBBER GROMET WUITH A CLIP REMOVE AND SEE IF ANY WATER DRAINS OUT IF SO TIP BACK TO REMOVE ALL EWATER THEN TRY
Thanks Quick Fix. The solenoid operates when the srart button is pushed in, but it does not latch in position. The means that when the start button is released, the solenoid drops out. Is ther another part of the circuit which keeps the solenoid engaged, e.g. the timer?????
