Tricity-Bendix Washer
  • #33966
    cornflakes
    model AW1200W – prod 914780707 00
    unit will not action, select any programme no fill or other single operations..drain..spin only
    I suspected door interlock..removed same linked live/switch wire
    same none action as when door is closed
    no lights flashing when start is pressed..ALTHOUGH PUMP RUNS FOR ABOUT 3 SECS sometimes on drain and spin only selcetion but not every time
    3 year old machine any starting point most welcome
    many thanks
    Graham
    Leicestertshire
    #240705
    try getting inside service mode and see error code… but more likely is about heater problem…
    #240706
    BobHope
    Re: Tricity-Bendix Washer
    i agree with Baron on this one, most deffo the heater has earth leakage. 😉
    Bob.
    #240707
    cornflakes
    thanks I will pat test it on my return
    #240708
    cornflakes
    revisted this appiance, change heater unit
    test as follows unit appeared ok
    watewr intake//drain..fast spin
    left client to do full wash
    called yesterday washer just washing,washing ,washing
    made late call last night
    no lights on any programme selection, other than ean flashing
    it will respond to spin,rinse but again no indicator light lit
    END light flashes 7 times.pause 7 times pause repletedly
    any ideas welcome
    graham
    Leicestershire
    #240709
    I think from your details (number of flashing “End” led) is “E70″series and it’s NTC related… check NTC and his wires to board…
