Tricity Bendix Washing Machine AW1400W
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Tricity Bendix Washing Machine AW1400W
  • #12364
    johnnyhoz
    The washing machine stopped pumping, when I took the pump off it was very obvious that the pump was burnt out so I purchased a new one but when I fitted it the machine wouldn’t work. I removed the Module and again it was obvious that a component on the board had burnt out it was black and charred. I fitted a new module now all the led’s flash but nothing else. I acquired a manual but it doesnโ€™t mention if all led’s flash what to do
    #149347
    Re: Tricity Bendix Washing Machine AW1400W
    All the LED’s flash do they Johnny, are you sure? Usually the LED’s act as an error coding to indicate the fault (some lit, some not). If all the LED’s are lit I would suggest getting prepaired for bad news the best option ๐Ÿ™
    #149348
    johnnyhoz
    Thanks Martin, a electronic friend who is not in this trade but has come across a similar problem suggested there could be a configeration code which he says maybe necessary to tell the board which model machine it is fitted to. If this is true where would I get this code from?
    #149349
    johnnyhoz
    Hi Martin and for anyone else looking,
    I’ve just found out that there are at least two variations of the module for this model therefore I believe I may have the wrong module I’m just cross referencing with the Production number and I’ll report back when I’ve tried it.
    #149350
    Dave_Conway
    There are three different PCBs for this model, all are pre-configured so they (in theory at least) should just work after fitting.
    I think you’re right, you have the wrong board ๐Ÿ™
    #149351
    johnnyhoz
    THAT WAS IT
    THE WRONG BOARD
    I’LL KNOW NEXT TIME
    IF I REMEMBER, THE OLD BRAINS GETTING WEARY
    THANKS FOR THE HELP
