Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Tricity Bendix washing machine diagnostic
- This topic has 8 replies, 3 voices, and was last updated 15 years, 5 months ago by
gjf60.
October 16, 2010 at 9:15 am #58021
gjf60
ParticipantI have a Tricity Bendix AW1201 and for the second time in its first 3 years its not getting up to temperature. I had the heater/thermostat replaced and I think its gone again. Does anyone know how to put it into diagnostic and the fault codes. I saw the service engineer do this when he came by rotating the programme dial. Is this a common problem with these.
October 18, 2010 at 6:16 pm #333110Seamy
ParticipantRe: Tricity Bendix washing machine diagnostic
When you say its not getting up to temperature do you mean its heating or not heating at all.
If you feel competant to do so you might look at the heater first.
If you don’t perhaps employing an engineer who can diagnose the problem may be best course of action to take.Fault codes & access to diagnostics are not available to the general public.
October 24, 2010 at 1:52 pm #333111gjf60
Its heating but its not getting hot enough. I think its the thermostat. I have the old heater element and it is part of the the thermostat is on the heater element. I could replace it again at £25 but is this a part that only lasts a year or two and I was wondering if I could bypass the thermostat or wire in a separate thermostat.
October 24, 2010 at 6:53 pm #333112gandh1
erm, yeh ok, if you want to potentially set fire to your kitchen.
ask yourself why the hell you have a thermostat connected to a heater.
be it in a washing machine, cooker or radiator etc.
its so the temperature can be controlled. to consider bypassing a stat is just mindless ignorance, and to even suggest trying that, would imply you’re far from adequately competent to work on your own machine. so from a friendly point of view, pls dont expect any engineer to further help if you cant recognise this, because the balance of responsability will be shifting from you to them…
besides, if you could wire in a separate stat, where would you obtain it from??
October 25, 2010 at 9:50 am #333113gjf60
OK so forget that but do you know if these heater thermostat combination on this machine usually last just one or two years. My previous machine was a Creda and I had it for 12 years before the bearings went and that had no trouble with the thermostat presumably it was separate from the heater.
October 25, 2010 at 10:43 pm #333114gandh1
sold loads of aw1201s and been out to a few of them. none of the problems ive come across have involved the heater/ntc stat failing yet. was it elux/tricity/zanussi’s service force or some other group who replaced the heater last time???
biggest issues with them was blocked filters.
and what makes you think its not getting hot enough? are you washing a thermometer or one of those ultra-trendy-in-the-90’s global hypercolour colour changing t shirts??? or something liek that ???
October 26, 2010 at 9:47 am #333115gjf60
I bought the 1201 from John Lewis and they picked up the fault under the 2nd year of the warranty and sent out Service Force to do the repair here in Leeds.
The first time I noticed my towels washed at 60c were not usable as long and so the next time I washed them I felt the door glass at regular intervals as it should have been heating and it only just got warm even just before the end of the wash cycle where as normally it would be hot to the touch. When the engineer came out he put it into fault diagnostic and then replaced the heater/thermostat he said with the genuine part 1325347100.
Its now doing the same again after just over 12 months, so maybe I’m just unlucky.
October 26, 2010 at 10:43 am #333116gandh1
well. put it this way. if you didnt make a note of the engineers twiddles on the machine, and dont want to pay for an engineer to come out and assess the machine, all you can do is replace to fix.
you know your old part no. which has been superceded by this:
http://shop.ukwhitegoods.co.uk/Washing+ … ement.html
im sure if you order it from ukwg you will get all the assistance required to help you fit it. there are tutorials elsewhere online and im sure a couple on here about it too.
The other thing to consider is that teh tags on the element might have corroded if its been poorly fitted and leaked onto it, the wires on the ntc can pull out easily, or if they haven been re-secured, been chaffed through, or as an outside possibility, massive limescale buildup on the ntc sensor
October 26, 2010 at 11:01 am #333117gjf60
OK I will try and find a tutorial about replacing the heating element. I presume its behind some kind of panel at the back. I couldn’t see all the twiddles to put it into diagnostic and I suppose its a trade secret but I’m surprised its not available online by now but I cant find it. I managed to repair my PC monitor (faulty transistor and resistor) and get a schematic online but not how to put my washing machine into diagnostic. Anyway thanks for your suggestions.
