Tricity BK111
  • #30248
    Lyric
    I hope that there will be an answer out there, the previous ones were perfect.
    This is a semi integrated DW that the builder fitted as part of the kitchen 12 years ago. It has been declared BER. I am getting a replacement which is also Semi integrated, my question is how do I remove the door furniture. I can’t see how it is attached. I do not have the Installation instructions.
    Can anyone remember ?
    #226503
    Re: Tricity BK111
    This is the AEG-built machine IIRC. There should be two screws down near the hinges which go clean through into the wooden panel. Undo them and give the panel a wiggle and it should come off – the top fixings were a “keyhole” fitting from memory.
    HTH,
