visited today
fault reported — electronic clock Flashing contiually when switched on at isolater
throught re-set will cure………….unable to re-set none of the buttons depress..removed a couple and find thick grease on shafts. suspect fluid egress that has gone solid.
client has not got manual,so I was not sure which set of buttons to press as this is double upper and lower oven timer unit. with 2 rows of buttons, although I would not have throught it any different than similar timers press and 2 and turn clock button.
thinking timer is u/s any idea of availibiliy and cost
thanks
Graham
Leicestershire
