tricity sovereign cooker
Home Forums Public Support Forums Help And Support Cooker And Oven Forum tricity sovereign cooker
  • #6440
    zozcat
    hi there
    i have moved house and it has a tricity sovereign model 4638 electronic oven control cooker but i dont know how to use it. i have tried pressing various knobs but it just keeps flashing at me on the lcd panel.
    can anyone help please
    #117669
    Dave_Conway
    Re: tricity sovereign cooker
    Yep, you need to set the time of day first.
    On the bottom row of buttons, press and hold the three on the left all at the same time, then turn the adjusting knob on the far right untill the correct time of day is displayed.
    Once you’ve done that, you can set the oven temperature for both ovens via the timer unit by holding the relevent button down and turning the adjusting knob untill the desired cooking temperature is displayed, once you release the button, the oven will start up.
    If though, the lights keep flashing from left to right and you are unable to set the time of day, the timer unit will be faulty as this was the most common complaint with them. New cooker time then I’m afraid as the timers are now obsolete.
    Hope that helps, let us know please.
    #117670
    I have a Tricity sovereign timer or two.
    Used to work for Electrolux (who owns the Tricty name.
    Reply to simonjoy~simonjoy.freeserve.co.uk if interested.
    #117671
    Dave_Conway
    simonjoy wrote:I have a Tricity sovereign timer or two.
    Better grab ’em quick someone, they must be the only two new one’s left in the UK 😆
    Simon, could you email me as a reminder, if anyone should ask on another forum I’ll put them your way 😀
    #117672
    Does anybody know if you can obtain a new top for the Tricity Sovereign cooker
    #117673
    Dave_Conway
    Which model is it dougill ?
    I’m guessing 4638 but there were a few versions.
    #117674
    zozcat wrote:hi there
    Press the lower lefthand 3 buttons of the block of 4 x2 buttons simaltaneously and rotate adjacent knob to set the time – release the 3 and you’re in business
    #117675
    larnerp
    Zozcat, I have a Tricity Sovereign 4638 and can scan the manual for you if needed.
    Paul…
    #117676
    spinner421
    Hi Larnerp,
    Any chance you could scan manual for me please? I’ve just moved into house that has this oven and i cant work the thing out
