Home › Forums › Public Support Forums › Help And Support › Cooker And Oven Forum › Tricity Sovereign cooker
- This topic has 14 replies, 4 voices, and was last updated 21 years ago by
cheerful.
March 14, 2005 at 12:18 pm #8465
cheerful
ParticipantHi
I have a Tricity Sovereign cooker model no. 4638 one of the 1800w Halogen light Heat areas has stopped working. Are they still available to
buy? if so where do I purchase it from and would you know the price?also couldyou you tell me how do I remove the glass ceramic top to replace the halogen light
Thank you kindly in anticipation of your reply.
Regards ,Happy
March 14, 2005 at 1:38 pm #128747Dave_Conway
ParticipantRe: Tricity Sovereign cooker
Very obsolete now I’m afraid as are many of the spares for the Sovereign cookers.
Sorry !
March 20, 2005 at 7:56 am #128748admin
KeymasterRe: Tricity Sovereign cooker
I also have a Tricity Sovereign model 4638 but the oven controller appaers to have gone U/S.
If the parts are no longer available for these ovens would you consider breaking your unit for spares? 😕
March 20, 2005 at 4:06 pm #128749larnerp
The fan in the back of my Tricity Sovereign 4638 (the one visible through the bottom oven is running slowly (despite servicing). I am looking for a replacement. If you (cheerful or ticcy_tickford) are breaking the oven, I’d be interested in a replacment fan.
Paul…
March 24, 2005 at 5:17 pm #128750cheerful
To Paul + Ticcy
As the cooker apart from one halogen hob is perfectly OK I have no intentions of breaking for spares, however if either of you two decide to scrap your cookersI will be interested,
March 24, 2005 at 6:49 pm #128751larnerp
Sorry, but I’ve just ordered a new fan motor for mine, which should get it going again for the time being, so ours won’t be scrapped for the time being….!
Paul….
March 27, 2005 at 12:21 pm #128752cheerful
Paul,
Where did you order the fan from? as i can’t seem to find anyone who has the part I need.
Cheerful
March 27, 2005 at 1:33 pm #128753Dave_Conway
In the shop now for you (even more) cheerful:
(No longer available)
March 28, 2005 at 7:52 pm #128754larnerp
Thanks for your post, Dave … that makes me feel less “Cheerful” as I’ve just shelled out £41 with Spares R Us for the fan motor. Having said that, it hasn’t arrived yet and if it doesn’t do so in the next couple of days, I will cancel the order and order the fan motor from the online shop at £25.
For what it’s worth, Cheerful, the web address is http://www.sparesrus.co.uk, but I’ve had a look and they don’t have any of the halogen light heat areas, which is the part that you were looking for, wasn’t it?
Good luck with your search!
Paul….
March 29, 2005 at 9:52 pm #128755cheerful
Hi Dave,
Were you talking to me when you said the Halogen Light Heat Area was in the shop now,??if so where as I can’t see it.Best Regards,
Cheerful
March 29, 2005 at 10:16 pm #128756Dave_Conway
No, I was refering to the fan motor 😆
Sorry, it got a bit confusing at one point, three conversations going on at once 😉
The halogen (which is what you are after), can you post the voltages and lengths of the tubes as someone may have some.
March 31, 2005 at 10:24 pm #128757admin
There have recently been enquiries about the availability of a Tricity Sovereign 4638 available for spares.
I have one in Bristol. We have just acquired a replacement cooker so wondered if anyone would be interested in the old Sovereign? 😆
Everything is working except main oven door RH hinge spring is broken, timer unit doesn’t select numbers easily; switch contacts shaky – but temps and timings are accurate, and main oven door seal is stretched a bit along the bottom.
Open to offers, regret buyer collects.
April 3, 2005 at 5:32 pm #128758admin
B-1-4,
My Tricity sovereign has a similar number selection problem. In fact the ovens are useless. Are you able to select numbers on the rotary selector?
If it works, I live in Penzance, but sometimes come past Bristol – would you consider £5 to take off your hands?
April 4, 2005 at 10:28 am #128759admin
Stilts
Yes we can select all numbers, temperatures and times, but it just needs a delicate touch and a bit of patience. We’ve lived with the problem OK for last couple of years, and used the automatic settings on a very regular basis.
Only reason for getting rid of it, is because we’ve just acquired mum’s newer creamic top cooker.
We would prefer it going to a good home rather than the tip so will be prepared to accept your offer if you can collect within a reasonable length time – it’s sitting in the conservatory at present!
April 4, 2005 at 7:47 pm #128760admin
KeymasterFurther to our reply above (Guest) – if you wish to set up a visit our e-mail is
ian@pfabristol.flyer.co.ukBTW we are not really breakers, just have a cooker to dispose of! 😉
