Been out to this condenser dryer, sympton’s not heating.
Element and cut outs are ok, it all seemed to lead back to the timer? After checking the parts diagram, it shows a thermostat, any idea’s where this is located and is it going to be the likely culprit.
Regards
Merv
If you lie on your back in front of the machine, stick your head in the drum while trying to get an arm and a torch in there as well. Then there are 2 screws that hold a stat in , at about the 12 o`clock position in the front.
