tricitybendix biw105w washing machine
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries tricitybendix biw105w washing machine
  • #67146
    Gordy29
    runs for about 30secs,after start button is pushed then go’s to end on any prog.heater ok also motor ok.any advice please.thanks gordy29
    #366481
    QUICK FIX
    Re: tricitybendix biw105w washing machine
    need to access the diagnostic check
    #366482
    QUICK FIX
    sorry hold sart pause and button beside it then turn on.turn dial 1 click left still holding the buttons for 5 secs then release the lights should start to go through one by one,turn dial another either 8 clicks or 9 and the fault code should be there count the two lights that flash and how mant times they flash you have then the fault code
    #366483
    Gordy29
    thank you quick fix.gordy 29
