Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › tricty bendix dh 104w tripping rcd
- This topic has 9 replies, 3 voices, and was last updated 14 years, 11 months ago by
slyp98.
May 4, 2011 at 4:27 pm #62586
slyp98
Participanthi all , having a bit o trouble with this customer sayes its tripping main rcd 60a and not the socket rcd , it starts ok then after a few minutes trips the rcd . the door switch doesnt work i dont think that has anything to do with the problem circ motor working ok and pump also working no sign of water anywhere and the element is reading 26.5 ohms anyone have any info on these models thanks
May 4, 2011 at 6:53 pm #350554BobHope
ParticipantRe: tricty bendix dh 104w tripping rcd
does the door latch close the door correctly if not it will be water ingress into the door lock assembly.
11 digit PNC code required if you need parts or info
Bob
May 4, 2011 at 7:07 pm #350555slyp98
cheers bob pnc is 911911018/02
May 4, 2011 at 7:20 pm #350556BobHope
pm me your email and i will send some info.
Bob.
EMAIL sent.
May 5, 2011 at 7:54 am #350557slyp98
i had a look last night yeah the door is closing fine bob i’m trying to pinpoint at what stage the rcd trips , it takes in water does a quick rinse and then trips . if you move the timer on a bit it starts up again (after resetting the rcd) which leads me to believe its a component , maybe stat or a solenoid or the timer itself
May 9, 2011 at 4:08 pm #350558slyp98
more sinister problems , i need a wiring diagram , is there any test procedures for these models ? the door switch when operated trips the rcd ! it will work ok with the switch removed from the door until a certain point in the cycle and then trip also , ive checked everything door wiring , motor , pump element, solenoids ,stat
May 9, 2011 at 4:17 pm #350559BobHope
pm me ou email address and i will forward some info.
Bob.
Emails sent.
May 9, 2011 at 9:36 pm #350560slyp98
hi again bob no sign of a wiring diagram , anyone else got one thanks
May 10, 2011 at 7:39 am #350561Martin
slyp98 wrote:anyone else got one thanks
Let me have your email and I’ll send you a copy…. 😀
May 16, 2011 at 12:38 pm #350562slyp98
ok solved this baby , pipe from heater element on outside r/h side to the top spray arm , water leak a trickle down outside of tub hitting motor , element etc
