Tricty Bendix WDR1040W
  • #24224
    Bernie
    I have the same fault as ‘Deltra’ (his is on a Zanussi) when it comes to the fast spin tries to pick up but doesn’t, it will try 2/3 times before timer advances and switches off, works ok most of the time on slow spin if its got a small load. Have tried it with small load, large load and empty but it will not go into a fast spin.
    Have meggered motor tested ok, and checked pressure switch.
    Any help appreciated
    Bernie
    #201192
    tanner
    Re: Tricty Bendix WDR1040W
    un balanced load could be tacho or module more liklely to be 1 or 2 heavy items such as towels or even a buckeld drum all need taking into account
    #201193
    Bernie
    Just for info, the fault was the Timer.
    Fitted recon EMW (thanks Tony) works fine now
    Bernie
