Tried Everything (nearly), Still Problem, Help! HVR HC120MUK
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Tried Everything (nearly), Still Problem, Help! HVR HC120MUK
  • #30579
    laurenceuk
    The problem is that the machine sticks in the prog at the spin point as it
    transitions from the wash to the first rinse eg. between 4 and first rinse.
    The machine will stay just ramping up to fast spin then slows to a short
    tumble then repeats this cycle continuously. The customer can click it
    on and it will continue to do the wash.
    This will happen in the delicates also – between 7 and rinse (I think it is).
    I have changed the slave timer, the board has been tested by EMW, the
    heater is OK, pressure switch appears ok, stat about 35k (ambient) – if
    I remember correctly, motor functioning.
    What else is there?
    Anyone give this confused guy 😕 any insights.
    Laurence
    #227690
    laurenceuk
    Re: Tried Everything (nearly), Still Problem, Help! HVR HC12
    Oops
    It is a Hoover HC6120MUK
    Laurence
    #227691
    Seamy
    Had a problem similar to this with a faulty pressure switch on these machines before.
    I think from memory it thinks its in flood condition, when it gets wrong signal from pressue sw’ .
    #227692
    laurenceuk wrote:The machine will stay just ramping up to fast spin then slows to a short tumble then repeats this cycle continuously. The customer can click it on and it will continue to do the wash.
    Whats happen if you select only spin program?
    If it has same result, I think problem is in motor or with his wires. Perhaps motors has stator with three wires on which middle one is defective…
