Tripping electrics
  • #95190
    clive2702
    Hi, got a range style cooker with electric solid hob plates.
    When the oven or grill or hob is used it’s ok, but if I turn on all the ovens and hob plates, the electrics trip after a few minutes.
    If the individual components work on their own but not when everything is turned on and up to full heat, does that mean there is a problem with the house electrics and not the range?
    #459655
    don
    Make and model number would help 🙂
    #459656
    clive2702
    Yes, sorry, it’s a Leisure rangemaster 110.
    4 solid hot plates on Lhs, griddle and halogen on rhs.
    Electric grill and convention oven on Lhs, electric fan oven and compartment drawer on rhs
    #459657
    What is tripping ?
    MCB which is the fuse for the circuit and then only that circuit trips. If this trips what is the rated current
    RCD which detects earth leakage. if this trips a number of circuits go off. Also has a test buttin
