I have a F&P Dishwasher DS301. I usually run the eco-program for 42 minutes. Recently the machine has started stopping at 40 minutes, 20 minutes and 13 minutes, where it starts beeping and flashing. There is a symbol with a watertap and a crossed line (as if it lacks water).
I have found no trouble with the drain and water supply.
For some strange reason, it helps if you press start – then it sometimes continues the program, at other times it runs for a minute or two – still showing the same number of minutes on the display – and then stops again. Lately I have to press “start” several times – always at the same minutes in the program (I’m guessing it takes in water or drains). But as it can be beaten to continue the program, I can’t understand the nature of the problem – unless it’s somehow electrical.
Please advice! And many thanks in advance!
