trouble with neff oven (U1721NOGB/01)
Home Forums Public Support Forums Help And Support Cooker And Oven Forum trouble with neff oven (U1721NOGB/01)
  • #17469
    protexblue
    The element in the bottom fan oven blew and I fitted a new one.
    Now I notice that the Temperature light never goes out, even though the oven temp is clearly high enough (presumably this is why the element blew in the first palce)
    Has the thermostat stopped working? If so, which one do I need and is it easy to fix (I managed to fix the element ok)
    #174506
    Re: trouble with neff oven (U1721NOGB/01)
    Yes either the thermostat was affected by the element blowing up or it was damaged when replacing the element. (The t/stat phial is easily knocked when removing and refitting the rear plate?)
    A new stat is Part No: 489378 and available by emailing these details to spares@ukwhitegoods.co.uk.
    #174507
    gegsy
    Is the circotherm fan turning correctly?? If it slows or even stops you will get the inefficient heating you are experiencing. This could also be the initial instigator of the element failing.
    protexblue
    the fan is turning fine, and i the t/stat file seems pretty solid to me and untouched – so i will try fitting a new t/stat – thanks for your help
    btw, why do the fans go so noisy so quickly???!!!
    #174509
    gegsy
    Its the nature of the beast Im afraid. In order to blow air around oven cavity it has to suck air in, this air is usually loaded with grease particles and finds its way down the fan motor shaft and into bearings.
