My Aquarius 1100 WM63 washing machine does not start. It is out of warranty.
When I close the door and try to start it, nothing happens: no noises, no smells, etc. I suspect that the door mechanism is at fault: when I close the door, the indicator light does not come on.
It is plugged in; the fuse in the plug is working; the circuit breaker in the flat has not tripped; hot water is on in the flat; nothing’s changed with the hoses (no leaks, etc.).
I suspect that I need to replace the door mechanism, but wanted a second opinion before doing so.
If anyone had any diagnostic or troubleshootig suggestions, I’d be grateful. (I’ve got a full toolkit, know how to use a multimeter, etc.)
Thank you,
Colin
