Home › Forums › Trade Technical & Spare Parts Forums › Trade Spare Parts › True Manufacturing Co. Display drinks fridge thermostat
- This topic has 7 replies, 3 voices, and was last updated 17 years, 9 months ago by
whiskeyjack6058.
July 9, 2008 at 8:38 pm #37998
whiskeyjack6058
ParticipantI have been out to one of these True manufacturing Co display drinks fridges.
This one is promoting Coca Cola and its model number is: GDM-23.
It is in need of a thermostat as the one on it is freezing up.
Not sure what stat I need and if its an air stat or not? I don’t think it is as the stat fitted has it’s capillary tube pushed into a thin copper tube by what seems to be the evaporator.
Never done one of these, would like to learn more especially considering this one is sat in my local fish and chip shop with one of my adverts hung up on the notice board 🙂
Any advice is much appreciated!
Thanks,
Rob.July 9, 2008 at 8:40 pm #257364whiskeyjack6058
ParticipantRe: True Manufacturing Co. Display drinks fridge thermostat
Oh,……………. forgot to mention, the thermostat that is on it is just a normal VT9 domestic fridge stat which another engineer fitted to no avail.
July 9, 2008 at 9:51 pm #257365admin
KeymasterRe: True Manufacturing Co. Display drinks fridge thermostat
Its a air stat that is required.
It shouldnt be fitted into the evaperator.Bryan
July 9, 2008 at 9:53 pm #257366whiskeyjack6058
Ok Bryan, do you have any idea where the stat sensor goes?
Thanks,
Rob.July 9, 2008 at 9:57 pm #257367admin
Anywhere below the air flow from the fan
bryan
July 9, 2008 at 10:04 pm #257368whiskeyjack6058
when I was there looking at it todat, I had to remove the stat from a detachable plate fitted to the top of the cooler. It would seem there is no fixing for the stat to go????
http://www.truemfg.com/CC_catalogs/true … GDM-23.pdf
That is a link to this type of unit.
Rob.July 9, 2008 at 10:13 pm #257369kwatt
whiskeyjack6058 wrote:I have been out to one of these True manufacturing Co display drinks fridges.
The thermostat that is on it is just a normal VT9 domestic fridge stat which another engineer fitted to no avail.
Thanks,
Rob.It confuses awfully when you use different threads Rob, especially with the same title. 😉
July 9, 2008 at 10:16 pm #257370whiskeyjack6058
Yes, sorry about that Kwatt, I put it in here first, then decided that I wanted it to go in trade technical…..DOH…
Rob.
